1 - 6 of 6 Posts
every 3k i usually do the oil and filter, check fluids, inspect brakes and belts, tires, and air filter, scan pcm w/my handheld
for high milage tune up of if is suspect problems,
air filter, plugs, wires, (distrib rotor/cap if equiped), pcv valve, coolant flush, thermostat, fuel filter, inspect and grease suspension, inspect brakes and flush fluid, oil + filter, if auto trans filter and fluid, gear oil, inspect belts, scan pcm w/ my handheld.
1 - 6 of 6 Posts
