1 - 20 of 22 Posts
Newbie!!!!
Found one on local CL. He wants $350 for it. Wondering if its worth it and if any good. Thx
buy it and trade me for my track heat.
Newbie!!!!
Same guy has a set of afr 165 heads. Said hed make me a deal of $1200 for both. Bout how much.power you guys think id pick up doing those two mods
Offer $900 for every thing
Newbie!!!!
OK so I talked to a buddy that has and has had a ton of mustangs. He told me to buy the intake but not the heads. He said I needed afr 185s. He said for the money I would be disappointed with the 165s. That they weren't much bigger than the stockers I have now
You're buddy is half right. The heads are night and day compared to stock heads. 185's will require a simple piston notch and won't just bolt on without modification or different pistons if yours are stock.
Couldn't he just put a thicker headgasket on with those ?
No not usually
Sent from my SPH-D700 using AutoGuide.Com Free App
Newbie!!!!
Discussion Starter · #12 ·
Ive got forged flat tops, but lets talk power. How much?
How would we know, u haven't gave us any specs on combo
Newbie!!!!
Discussion Starter · #14 ·
Whats in my sig is what i know about the car. I bought it as is. Basiclly a stock 306 with forged flat tops and a b cam and full msd ignition
Exhaust fume addict
With those heads and intake probably between 230 and 280 rwhp depending on the CR those pistons give you. And whether you are stick or aod
Newbie!!!!
Discussion Starter · #16 ·
For the $ spent should i just try to find some 185s?
Exhaust fume addict
And I would figure out what the +/- CC is on those pistons. That will effect your build alot
If you can score those heads and intake for 800-900 combined it wouldn't be bad. And if you are a stick and those pistons are truely flat tops I bet you will make closer to 280. They are still gonna be way better than stockers
Newbie!!!!
Discussion Starter · #19 ·
He said $1200 for the combo was bottom dollar.
Car is a 5 spd
How do i find out what pistons are in the car
Exhaust fume addict
Too much when a set of trick flows new are $1100
I have no clue how to identify a piston, hopefully someone else does
1 - 20 of 22 Posts
