1 - 2 of 2 Posts
Stupid rpm keep dropping lower then up den die wat heck. I deep cleaned the ivac, tb is clean, tps is .97 Idk wat else to look at. I don't think I have vaccum leak. All plugged in tight. And Idk y battery suddenly drain out after I replaced clutch then pressure plate. All lights works but dying. Needed to jump n hold tiny of gas to keep idle up. If its parked overnight itself recharged up to 8v so I'm assume alt is still good. Tomorrow mornin I'm go to autozone n see load test if it hold up. But help me out with rpm issue? Thanks in advance.
Discussion Starter · #2 ·
Lol another problem solved just right under my nose! I was playing wit fusebox. Put all new fuses. Suddenly battery drained. Duh I don't have radio so yea it was shorting the battery out. Jus remove radio fuse. Recharged the battery and started fine but rpm still doing same thing.
1 - 2 of 2 Posts
