1 - 3 of 3 Posts
I need to run a wire from the battery, through the firwall and into the passenger side under the dash board. Are there any existing holes that i could use to route the wire? I have found gormets on the inside that have wires runnig through them already but i cannot find where they lead into the engine. Please help!
MOAR BOOST
There is one that leads into the drivers side compartment above the gas pedal...idk about on the passenger side. The one that goes to the drivers side is pretty easy to find in the engine bay, just look on the firewall of your drivers side and you will see it.
Open your door. When you do you will see a hose where all the wires from the door is. Run it on the side of that finder and have it go through he rubber hose (where it goes into the door only) and your done.
1 - 3 of 3 Posts
