1 - 4 of 4 Posts
I have the RXT clutch with a Fidanza steel flywheel. Clutch is awesome but I've always had disengagement problems with it... as in it doesn't disengage all the way when I push the clutch in. I've got spacers behind the slave cylinder and have tried several new oem slaves but it never disengages all the way.
When I had the original RST clutch in it, it was fine. As soon as I went to the RXT the disengagement issues appeared.
Anybody know of issues using the RXT clutch with a Fidanza flywheel???? Maybe the master cylinder can't support it?
Currently assuming 8-] I have the old style clutch like the one that broke in that thread. I keep putting spacers behind the slave cylinder but doesn't gain me anything. I've never looked *that* close at the clutch when I had the trans out. That's probably been my biggest mistake. :) I'll find out soon enough.
Are you sure that's the issue or you're just assuming it?
1 - 4 of 4 Posts
