1 - 16 of 16 Posts
Exactly what the title says. would it be safe to run 100shot of nitrous and Drag radials? Thanks
all day long, I ran my car for about a year and 25-30 15lb. bottles. never had any issues.
Only with a cam spray mod.
Yeah i really dont want to launch with the nitrous, but i installed a window switch and the POS wouldnt work properly. It would allow the nitrous to come in any gear and any RPM at 1/4 of a throttle or more. It pissed me off. But im running a zex system
for a zex kit your good for the 125 shot, they rate their hp at the flywheel. You should put around a 100 at the wheels.
and remember its the tq you got to watch, I would stay at the 125 and no higher. Also what plugs are you runing.
Only if you run Vossen wheels. You know, for hottness. 'Cuz they are the hottest.
:shiftyeyes
Discussion Starter · #12 ·
:shiftyeyes
Hahaha nah running the stock 18s which aren't bad but aren't that hot
Discussion Starter · #13 ·
I'm just Running a 100 shot. Not even a 125 haha. But I'm running stock plugs but backing the timing down 2 degrees when I run. Loss alittle power but I like being safe haha
Get a non platinum plug 2 degrees colder and a proper tune or your gona be rebuilding the engine.
If you dont, then please dont blame the nitrous when your on the side of the road waiting for a tow truck.
Lets see... A tune for cams which will add timing
Stock platinum plugs with stock gap
No window switch
No fuel preasure safty switch
Not trying to be a douch, Im just giving you a few things to think about when runing nitrous safely.
Discussion Starter · #16 ·
No window switch
I know your not haha. But i already have a tune for the nitrous which backs the timing off "use it every time i run the nitrous". I tried the window switch thing and the pos wouldnt work as stated. But i dont have a fuel pressure safety switch and need to get plugs. Ive ran nitrous on other cars and had no problem without anything except ive changed plugs. But i feel if i dont watch i will have problems with the DR's and nitrous. Thats why ive never used both at the same time.
1 - 16 of 16 Posts
