1 - 7 of 7 Posts
☼ny
I had all the valves hit the pistons on one bank of the motor. Pistons are forged from DSS.
Here's the damage...
I've started sanding the notches with some emery paper. Question is how much do I sand off? Should I just get rid of the raised edges or sand em flat or somewhat in between those?
Head Unicorn
Just the raised edges to eliminate hot spots. Minor work will clean 'em up.
☼ny
Sweet...I was hoping thats all that was required. Done that on 2 pistons already. 2 more to go.
How did you wind up with ptv contact with notched pistons ? :dunno
US Air Force (retired)
I would have them checked for fractures before putting them back in a motor.
☼ny
lifter failed, a rocker fell off n got stuck between cam lobe and valve, cam locked up, cam gear sheared off the key way...$H!t broke....
It happened at low rpms while tuning for idle...shouldn't have fractured the pistons(being forged n all). Sent the head to Trick Flow n they gonna fix it up.
1 - 7 of 7 Posts
