1 - 11 of 11 Posts
So I just got a new windshield, and before I got a chance to put Rain X or any protection on it, a tree I parked near at school dropped a bunch of little leaves all over my car (looked like little flower pedals.) I didnt think anything of it, but when I went to move it a day later I put the windshield wipers on none of the leaves came off. Came to figure out that they were covered in sap, and I picked them off my car one by one by hand. I washed it 3 or 4 days later when I went home and the sap didnt come off. I was able to get it off the paint by using a paint prep and lots of elbow grease (and the paint had a fresh coat of wax before this happened)
The glass in my car is still covered in little spots of sap and I have NO idea how to get it off. I tried the paint prep, multiple washes with car soap, windex, armor-all glass cleaner, and even razor blades. Nothing works, not even conventional de-bugging/tar removal stuff. What else should I try to get this sap off? Its really getting annoying having streaks across my windshield.
rain x sucks just to start off
and go get goo gone at autozone
oh and you could also clay bar it as well
Tried goo gone + rubbing and then a razor blade, neither worked. The clay bar worked really well for the paint, but didnt do much for the glass... I've never seen crap this resilient before
Photoshop Junkie
Maybe try acetone or alcohol. We use both at work for cleaning optical lenses. Just keep the acetone away from your paint.
There are quite a few ways to go about this. Goof Off or Goo Gone like suggested can and should work depending on the type of sap and how long it's been there, etc. However this isn't what I would do if it were my vehicle or any vehicle I was detailing. Wash the window with car shampoo, leaving the soap on the windshield, than using a plastic or metal razor blade to remove the sap. Just keep enough soap & water on the windshield to act as a lube and you will be golden.
Rain-X isn't that bad.
Presoak with Zep citrus at 3:1 in spray bottle or pressurized sprayer but do this at dusk so you can let it sit on the vehicle for 5 to 7 minutes without worrying about chemical etching. Then do a two bucket wash with Zep citrus at 3:1 and add 2oz of Dawn that should cut it. Zep citrus can be bought at home depot for $10 a gallon its a great APC and should break it down without a problem.
  • Like
Reactions: ReedsFX4
Thanks, I'll give this a try once it finally stops raining
I'll give this a try too if NastyStang's method doesnt work
Reps all around
It's in the details Mod!
Along with Danny's method, try using a nice warm water in both your Zep presoak and your wash bucket to soften the sap.
:yes Just make sure you do this wash when the sun is setting or barely rising to prevent chemical etching;)
Discussion Starter #11
NastyStangs method worked well, it took off the concentrated spots of sap after a while. I might try Danny's method for my rear window, which has this crap all spread out over it, not in built up spots.
First I have to go wage war on caterpillars though. The trees in my driveway are full of them and every time I wash or just leave my car out there for 5 mins its covered in caterpillar crap :mad:
1 - 11 of 11 Posts
