1 - 13 of 13 Posts
Pimp
What is the range on our FPDC live data log from the handheld tuner. 0.00 - 0.99?
Reason why im asking i know some are 0.0-0.5 x 2 = percent your pumps at. Correct?
With 0 - 1 x 100 = X% Which is what Livelink uses. Wouldnt the live view data logger thru the hand held be the same?
Some reason on Livelink its showing my two 340lph pumps are at 96% at WOT on 10lbs of boost.
Livelink is showing me 58% at idle/crusing speed. WOT 96%... which is NUTS i shouldnt be.
But thru the hand held, its 0.28 - 0.30 which is 28%-30% at idle/crusing speed.
Which guys with the same or similar setup are at these numbers. What Gives? Lol
WOT is 0.49-0.52 and obviously would be 49%-52%. Im so confused now.
LiveLink is using RTLS FPump DTYC
LiveWire shows FPDC.
Fuel Setup
RETURNLESS
60Lb Injectors
Modified FPDM W/Wire Upgrade
Cobra 03/04 hat.
2 340LPH Pumps
PPRV Delete
Aeromotive Rails W/-8AN line to stock 5/16 Line @ Firewall.
Any input would be greatly appreciated.
I am fairly certain on my livewire it is 0-.5 which requires doubling then multiply by 100 for fpdc.
The attached shows a piece of a log from livelink and the fpdc just needs to be multiplied by 100.
Sent from AutoGuide.com App
---------- Post added at 09:38 PM ---------- Previous post was at 09:38 PM ----------
My guess is you are only running on one pump or one of the feed lines popped. I run a single divisionX 340lph pump and at 11psi i am just at 90% or so.
---------- Post added at 09:41 PM ---------- Previous post was at 09:38 PM ----------
Dont look at the column headers for names of the PIDS i am logging. I renamed the columns to clean it up. The pids you list are what i am logging.
Pimp
Hey sonics thanks for the tips. U know a good way to test a pump other than a 9volt battery?
Dropping my tank tomorrow.
I do not have any experience with dual or triple setups but what i would try as a random guess is drop the tank and disconnect power one at a time from each pump then key on to confirm each primes. Obviously that proves nothing for flow.
Pimp
Ya well see. Thanks bud.
Ill update tomorrow. Hopefully it's easy fix.
Pimp
ImageUploadedByAG Free1373389602.119378.jpg ImageUploadedByAG Free1373389619.340558.jpg ImageUploadedByAG Free1373389642.638775.jpg
Here is what she looks like now. Tested both pumps with priming my system they spit fuel. So I don't know what else to do.
Since you know the test the volume output. 1 pump at a time and see if you are close
If its a 340 lph pumps you divide by 60 to get per minute and then divide by 6 to get you a 10 second amount. Approx a 10 second run should pump 1 liter of fuel
just a question did you upgrade the wiring to the pump because i thought the dual 340 was too much power for the stock fpdm and you might be running 100 percent of what the box can put out amp wise and not your actual pumps just my 2 cents here since i dont have that much experience with the mod motor cars
Pimp
Yes I have a modified fpdm I did wire upgrade from battery to 30amp fuse. Stock wiring in the hat.
What are the supply volts at through your run? Naturally as the load increases the voltage will begin to drop. As long as it does not dip below 12.5 or so it should be sufficient.
If you are willing to drop the tank again you could try running a single pump as a comparison to see if it is indeed the fpdm capping out.
Pimp
Discussion Starter #10
Ya was thinking bout that as well. I can send u a few data logs if ur interested. Just pm me ur email.
I was fine with 6 lbs of boost with one pump. Than went to 8lbs and 10lbs and all this happen. I think my second pump isn't working correctly. :/
Pimp
Discussion Starter #11
Well slight update.
Dropped my tank again decided to pull the pumps off and test them from a battery straight to the pump. 9 volt battery. One pump sounded pretty heathly and the other one seemed to go and lock up. Thought maybe the battery was bad. So i went ahead and tried it on the other one again and she spun great. Tried again on 2nd pump... didnt wanna turn. So i got a bigger battery. 12volt battery 4wheeler/motorcycle.
It turned but not very well.. So im guessing this pump is dying. Im sending it back to the guy i got em from to be flow tested and get the results.
Hope this is my issue and i can get it fixed. Thanks Everyone for the help.
Initially I was questioning why you were running out of fuel with the single 340 pump but now I see that you are camm'd so that explains alot. 10lbs on a cam'd car is more than my 11-11lbs non-cam'd.
Sounds to me like you found the smoking gun. Good troubleshooting and good luck getting it fixed quickly.
Pimp
Discussion Starter #13
Yes but its not much different than stock. We know turbos dont like big cams. lol
1 - 13 of 13 Posts
