1 - 11 of 11 Posts
just looking for tips and pointers on the sbc swap....will i have to put the tubular k member in or can i use the stock one?..
Best option is an AJE sbc swap k member, the stock one won't work without alot of modifications
  • Like
Reactions: rhineha6
Poor car
Super Moderator
welcome to MM
There are other options why a SBC?
unfortunately i dont think you'll get a lot of love in here putting a Chevy motor in a mustang....
  • Like
Reactions: rhineha6
are you referring to the classic 350 small block or an Ls1? an ls1 would have potential, but a classic 350 might not be worth the effort and cost for swapping it in. as stated, buying the K member will save alot of headaches.
what is the situation that calls for it? or the driving desire?
well we have a 2002 mustang with a blown motor, got a brand new 388 stroker on the stand...just curious to see how it runs....never done a swap like it so i want to try
My take on this... if the 388 is carbed you would need a kmember&possible suspension changes, fuel system, possibly cowl hood, and lots of odds and ends depending what accessories you want to run, etc. This could add up to some $$.
If the 388 is an EFI system, then you will need on top of the above, wiring and engine management/controls, so lots of $$ from above plus even more $$ for the EFI bits.
Both cases likely need a trans/trans work/modification to get that sorted as well...meaning driveshaft also...
In either case, the cost to bastardize your 02 with a chevy engine, is IMO far more than the cost of getting a decent used running 4.6 2V (I'm assuming you have a GT...if you have a V6 then there are even more things that for sure need changed (rear axle to handle the power (7.5 to 8.8), V8 springs vs. V6 springs to handle added front end weight, etc. etc.)
IMO the cost of this swap is very prohibitive, even if the engine is free. You are much better off getting a decent running 4.6 2V or rebuilding your current one, than putting that 388 in the car. A proper K member setup alone is going to be atleast $1k with the bare minimum, to do it right you probably need close to $2k or more in just suspension parts...
where are you located?
  • Like
Reactions: rhineha6
ahh I'm in Jersey and have an 88,000 mile shortblock sitting in the garage. just needs a dowel pin replaced for the timing chain arms.
1 - 11 of 11 Posts
