OK. Here is the chunk you are forgetting about, work.
A machine shop will charge about $500-600 for the over bore. then if you build it you still need atleast oversize pistons.
You will need new bolts and screws since you took the whole thing apart so that is another $130 for gaskets all around and another $2-300 for ford replacement bolts. $500-700 for arp pieces all around. Assuming you don't get all forged rotating assembly, which would be stupid but doable. You are looking at $600 for your pistons and maybe $100-200 for the pieces to put them on. Then you got to get it all balanced which i'm guessing will be $100-200 (not for sure on that one). So for your bottom end alone, your looking at $1400-2100 for the bottom end. Then you get the new heads which cost $2000 and cams for em for $400 and throw it all together your self.
Over all your looking at $2400 + $1400-2100 = $3800 - $4500 for your N/A set up that is only good to about 350 hp if your lucky. Throw in a worth while forged rotating assembly and new intake will bring you closer to 400 rwhp but bump your cost atleast $2000. So your looking at about 5800-6500 for a 400rwhp N/A car minus a tune.
Now your going to need a tune with the KB set up anyway so its really a wash to compare. The tune they give you is good enough to drive around with, but is really only to get you to the tuner without toasting your kit.
Of course if you get the K/B kit, you still don't have a built bottom end, so you can't put more than 450 rwhp out of it without worrying anyways. But, its still more power than you will get N/A, and it will cost less.
Of course you could get a Vortech kit if your into that for about $3000 all said and done and be at the same power rating (less bottom end torque tho)
