1 - 8 of 8 Posts
I just got my C&L CAI and SCT tuner from Brenspeed. I installed the CAI and everything went smooth, until I tried to install the tune.
The SCT powers up and lets me select Program Vehicle, but when I follow the prompts (press select, turn key on, press select, etc.) it gives me a time out error like it can't find the car computer. Same thing when I try to read the car error codes, it can't find the car. I followed the directions exactly and tried several times with the same problem.
Did I do something wrong or is the tuner bad?
I drove home 20 miles with the C&L but without a tune. I had just filled up with 93 octane in anticipation of installing the 93 octane tune. I didn't get any error lights on the car, but it seems to bog now. I tried to keep the RPM's under 3000 on the drive home. I need to get the tuner working so I can drive it with this CAI installed.
Any ideas, other than calling Brenspeed in the morning?
Doc
your pcm probably does not match the tuner is all.. common problem.
welcome to the forums man.. it is an easy fix.
Golf Pencil Kawk Juggler
could it also be he started the car rather then put it to accessory?
I didn't start the car, I did follow the directions, but it seems to not recognize the car.
If it has the wrong codes, can Brenspeed email the correct codes to me and I update the tuner, or does the tuner have to go back to Brenspeed?
Is this an easy fix in the morning or do I have to uninstall the CAI and put the stock back on and wait for a new tuner?
Has your car ever been back to the dealership for anything? If so they could have changed the pcm strategy different from the code you give brenspeed.
That sucks and would bum me out!
I just received my CAI and Tuner so maybe I should try to do the tuner first then the intake.
1 - 8 of 8 Posts
