1 - 11 of 11 Posts
PSN alphadong11
I have a timing light and hooked it up but are the marks on the harm-balancer supposed to line up with the arrow/spade thing, because if they are it is way off. All the book said that came with the light was to count the number of timing marks and thats it. end of directions. the balancer only goes to 10 deg each way right?
I would like to set it at 14. if anyone has some pics or a vid that could help me cause im not getting it after reading a **** load of "how to" articals.
I have a haynes manual but that doest tell me anything about how to do this.
first take brake cleaner or paint thinner to clean off the balancer then once its dry, take a white automotive crayon to mark the area then when you use the light you can see the marks a lot better.
Found this on another forum, hope it explains it better than Haynes.
1. First things first. You'll need a few things: a timing light, a distributor wrench or a ratchet and socket that will fit the distributor hold down bolt, and a little know how.
2. The first thing you'll have to do is disconnect the spout connector. Make sure the car is off when you do this. On 87-93 cars its at the end of a wire that is hanging near the distributor(C). On 94-95's its near the passenger side strut tower(B). The reason you disconnect the spout connector is so the computer doesn't automatically change the timing when you move the distributor, which will let you set the base timing. Oh and whatever you do....Don't lose the spout connector.
Spout connector
3. Next you'll have to connect the timing light. With most lights you have to connect the positive and negative clips onto the positive and negative terminals on the battery. Then you clip the inductive lead of the timing light onto the number one (1) spark plug wire. If you don't happen to know which one that is on a Mustang, then I'll tell you. If you are standing in front of the car looking at the engine its the first spark plug wire on the left side of the engine. See the diagram below.
Firing order
4. The next thing you will need to do is start the car. Before you do so there are a few things to look out for. First make sure there aren't any wires hanging near the belts, pulleys or fan You'll also want to check to make sure you can see the actual timing marks on the harmonic balancer. Some times is easier to get some whiteout and crawl under the car and mark where you'd like the timing to be set at, such as 14 degrees.
5. Before you start the car, loosen the distributor hold down bolt(D). Don't take it all of the way out, just loosen it a little. If you take it all of the way out the distributor gear may skip timing when you start the car up, which isn't a good thing.
Now start the car, and point the timing light at the timing marks(A) and pull the trigger (if it has one). You should see the light flashing on and off, and you should be able to see the timing marks, or the one mark that you made with the whiteout. Be careful, don't let the timing light, or even worse your hands get caught in the belts or hit with the fan.
Timing bracket
6. While holding the base of the distributor (not the top near the plug wires) turn it very slowly until you get the timing where you want. Then tighten the distributor hold down bolt and re-check the timing to make sure the distributor didn't move. Don't forget to re-connect the spout connector too.
7. There you go! You're all set!!! There are a few things you should know. Ford set the timing at 10 degrees from the factory so you could use low octane fuel. If you bump up your timing then you'll need to use a higher octane fuel, usually 91 octane. Although I've seen and heard of people running 18 degrees of timing without having trouble its really not recommended. When you set your timing too high your engine will ping, which will cause bad things to happen like blown pistons.
Try setting your timing at 13 and take a ride. If it doesn't ping then you can try setting it higher, but once it starts to ping turn it back down a degree or two. Basically what we are saying is be careful and, if you don't under stand any of this have someone who does help you.
Who Care's ... Boost It!
That's a nice way to put it. 5 Star service. You can come to greenville and replace all of Autozoine employees anytime
It's really very simple, yes the balancer is already on the engine. It's that round, thick chunk of iron behind the crank pulley.
dr.gonzo.... The pic you posted shows 10* ATD there should be another mark at TDC then on the other side you should see the BTD marks. Get under the car and clean the balancer so you can mark the correct lineswith some type of marker. (nail polish works wonders here LOL). You will want to be somewhere between 12-14*BTD.
PSN alphadong11
Discussion Starter · #11 ·
I finnaly got the rest of my exhuast hooked back up, it doesnt even feel like the same car now, after rolling around all winter with an open x pipe
1 - 11 of 11 Posts
