I have a tremec 3550 in my 94 gt with a steeda triax. at high rpms my shifter seems to rattle. all i have to do i put my hand on the shifter and it stops. whats causing this
+1check the plastic bushing that sits on the ball that goes into the trans
this could be but also depending what shifter you have the bushings inside wear out on some. (hurst is the worst)check the plastic bushing that sits on the ball that goes into the trans
Agree with this, I have a hurst shifter and mine has the same problem, but only at highway speeds in 5ththis could be but also depending what shifter you have the bushings inside wear out on some. (hurst is the worst)
