1 - 1 of 1 Posts
Hi All,
I have a huge coolant leak which seems to be coming from the area behind and a little below the EGR valve. It's not the water pump, it's around the top part or even further above the timing cover. Even when idling the coolant leaks profusely, to create a puddle within 10-15 mins. The leak is not coming from the top heater hose or the heater pipe that's near the water pump. Once the engine comes to temperature, I cannot drive more than a few minutes as it will start overheating. Has anyone experienced this ? Is this likely a blown head gasket ?
Any tips or suggestions greatly appreciated.
Thanks.
1 - 1 of 1 Posts
