1 - 16 of 16 Posts
I think I might just be more paranoid then anything, but I was making 10psi. I was on the dyno last week, and only made like 8psi. So I was thinking belt slip, today I got on it, it hit about 7psi. Max. When I blew the oil return line, some got on the pulleys and ****, so do you think the oil ruined that belt? Thats whats causing it to slip? Or could my blower be going bad? I would think if it was a seal, Id be leaking oil right?
I ordered a Gates 107.5" belt, right now its a $15 duralast 108" belt (little to big) so do you think thats my issue? I just want to make sure.
belt could have stretched over time and the warmer weather may be helping it stretch a bit causing it to slip a bit. Could be wrong its just a guess.
Yeah the gates belt should help you a lot. I've had my blower at 14psi with the gates belt and no slip at all.
Do you have a Vortech pulley? I still have the 2.87 I bought off you.
Your making 14psi, are you on the stock motor? Cams? How much power? I forget your setup man, its been a long ass time since you posted lol
US Air Force (retired)
Bearing noise, oil leaks are the usual signs of a bad supercharger with the result being loss of boost. Both oil on a belt and a belt that is too large will cause slippage. A weak tensioner spring will cause it as well. You might try to clean your belt with belt dressing. I don't know if its recommended or not but I sprayed a little brake cleaner on mine when I got a bit sloppy with oil.
Yeah I have a vortech pulley. That was with the 3.12 pulley I had. I'm only running a 3.33" right now with vt stage 2 blower cams.
Its so hard to tell with the bearings because the V1 is so loud. But it still sounds the same, so Im assuming no issues. I seriously doubt the blower is going bad, Idk why but that thought randomly popped up in my head.
I think its just a case of a shitty Duralast belt, some oil got on it, and its to big. The Gates 107.5 will be a lot better I think. The tensioner was replaced not to long ago, thats what was causing the belt to jump over a rib or tear completley. But Ive had all 6 ribs ever sence I did that.
I see, how much power are you making?
2018 Mustang GT Manual
My first sign of a bad blower is when she doesn't swallow.
j/k. It's probably the belt. Can you tell if it's slipping or not? The only other thing I could think of is the bearings or worse some crap got in there and chewed up the impeller.
Discussion Starter #9
:lmao
Its hard to tell but it just goes to like 7psi and kind of bounces alittle.
It's probably the belt slipping. Especially if oil got on it. For safe measure you might clean the pullies once the old belt is off. Belts are cheap so I wouldn't worry too much about it. If that doesn't fix it then you might pull it out and take a look inside. You just never know cause the vanes in those things are very sensitive to damage. However I highly doubt anything ever made it in there in the first place.
Discussion Starter #11
:lmao
Lol belts are "kind" of cheap, $40 and cant get it in the store around here. Then changing belts on a centri, omfg I hate it. Its such a pain in the ass. Need to get it up on ramps, back the bracket off, wedge the belt in a place you really cant even see, ef that.
But yeah I will, thanks for the help man, reps for you.
:yes A real pain. With the ProCharger bracket I have to take the bracket and head unit completely off and I still haven't learned to get the new belt back on without help.
Discussion Starter #13
Really? Completley off? That sucks. I take out all 4 of the main bolts, then I have someone lift it up and pull forward towards the front of the car so I can sneak the belt in on that idler. Then getting it all re-aligned and all that bs, its not fun at all.
Mine made 9psi with a Gates belt originally and then after about a month it dropped off to 6psi, but the car didn't feel any slower. I've also seen 4psi, 7psi, saw 8psi a few months ago in cold weather. I don't know what the deal is, but the belt will stretch over time.
I'm usually replacing it by myself then my wife comes out to hold the belt on the crank and power steering pulleys while I slip it over the tensioner pulley. A 108" belt barely fits. And yes, getting all the shims back in the right places is bs. Even when it looks perfect I get a little wear on the side of the belt.
this is exactly why i sold my s/c.
1 - 16 of 16 Posts
