1 - 4 of 4 Posts
Hey after reading how to on another forum, I finnaly disabled the skip shift fuction. I know this feature is on the 5.0's, but is it on the GT 500's?
How did you disable it?
Discussion Starter #3 (Edited)
How to: Disable Skip Shift - Ford Mustang Forums
check out that forum, and then this one.
How to: Disable Skip Shift - Page 4 - Ford Mustang Forums
It took me 15 minutes to do. One of the guys explains tha you need to use a rubber cap found in a coolant bypass kit to cover the plug to keep out dirt. I could not find this so I bought a bypass cap assortment found at OReillys. Checker or Auto Zone should have them also. The 1/2 inch cap will fit good but I had to use a zip tie around the cap before I slipped it on because without it it was a little loose. Just follow instructions on the posts. Car shifts like it's supposed to with no codes.
Yes, I am your Daddy
Or you can get an SCT tuner and disable it that way too
1 - 4 of 4 Posts
