1 - 20 of 22 Posts
well im getting real sick of that damn skyscraper of an antenna on the front of my car so..
my question is if i cut it will it effect my signal and how can i get the ball of the antenna back on to the cut part??
Resident Bubblehead
I know plenty of guys that have done the antenna mod and haven't had any radio signal issues. Just use a hammer to tap the ball back onto the antenna...
alright sounds good to me... does the ball screw off or is it pressed on? ohh and u guys have any pics
a.k.a. Racecougar
I cut mine down to roof height, and I don't have any signal issues here. The ball is pressed on. I shaped the end to press-fit back into the ball, put just a bit of JB Weld in the ball, then tapped it back on.
Resident Bubblehead
You should be able to use the claw end of a carpenter's hammer to get the ball off...
ahh nice good idea ill have to try that
got any suggestions on how short i should cut it??
Its easier to get the ball back on after you cut it if you grind it just a bit, and then use a little epoxy. Your radio signal shouldn't be bothered.
i bought the 14" antenna from AM and now my radio signal sucks balls. would a cut down stock antenna get better signal? but then again, i live in rural nowhere so that probably doesnt help...
BYAHHHH!
I have the 8in one and if you dont have your presets before you change it you cant find them after. Just goes through all the stations. But I listen to CD's and the 8in looks so much better.
The had been bugging me too. I'm just about to the point of cutting my stock one down to size as soon as I have a saw to use. Let me know how long you leave it so I can cut mine too.
I cut mine down to 8", my dad cut his down to 14" and both work fine.
Let me just tell you. I did it the DIY way. and if you don't have the right tools to cut that antenna with, it turns a easy 10 minute project into a nightmare haha. That antenna is one thick/strong piece of metal. and getting that ball off was other issue.
I still have to paint mine..
I don't listen to the radio.... But still have the skyscraper antenna. I suck :(
1 - 20 of 22 Posts
