1 - 4 of 4 Posts
So i can get ahold of a set of SLP Loudmouths 1 from a 2002 GT. But i have a 2006 GT my question is can i use them if i cut and weld them to my exhaust i have now. SO basically can i use the mufflers and different hangers ex.
I wouldnt see why not if you are gonna get it welded it ahould fit fine. Is the diameter the same? If so your probably good
you'll need to weld them in the over axle pipes. you wont need hangers for them if you do it that way. then you can either do a muffler delete, or get a strait through style axle back and use them as a resonator to cut down on trumpeting. should sound good. if you run them with a muffler delete, dont put an o/r x with it, trust me.
Hellmif you are weldimg em in you could mid mount em. That woukd be sic and sound good man.
1 - 4 of 4 Posts
