1 - 20 of 41 Posts
so can u put a turbo on a four banger when it doesnt have one to start with or do u have to swap?
you can put a turbo on any car.you will need a turbo exhaust manifold,
turbo,oil supply line, wastegate,BOV,downpipe,intercooler,oil drain hose,
and an fuel system that can supply your turbo.
not true, its better to use the E3 block from the TC and SVO, but try to find a turbo coupe for cheap and take it guts out and switch it to whatevere
Well, you CAN put a turbo on almost any motor (try turbocharging a radial!), but whether you should is another matter.
hey turboLX are you using any of stingers stuff if so what do you have?
yes i am, i am using a one of his headers, a 3" down pipe and soon to be getting an intercooler and a log style intake
Discussion Starter #13
i meen what all do i need to get if i have a stock motor. and around how much would it cost
r u sayin i just neede new pistins and the turbo kit or what
i would save the trouble and find a Thunderbird turbo coupe or Merkur that still has the 2.3t and use that instead, or check ebay, there always on there
do you have the 3' all the way through or are you running a "y" pipe with 2-1/2" duals?
im running 3" all the way into a y pipe that is 3" and all the way out
beeker said:
puting a turbo on an engine with cast pistons = BOOM !!!!!!
why dont more people in the 99-04 sections get this simple concept? :usa
so you're running 3" duals all the way back? man, that motherfucker must spool up REAL fast LOL :funnah
yea it does and im gonna put on glass packs too so it passes inspection, and its loud too, it sounds like a big ol' V8 especially because its a Holset HX35
1 - 20 of 41 Posts
