I remember a couple months ago I did a compression test on my car and all of my cylinders were at 150-160psi. Now, that seemed a little high to me for a car with more than 150k miles on it. I've always ran 87 octane in my car and it's always felt like it was lacking some power, even with the 4.10's. And it used to backfire through the intake but it hasn't since I did a tune up. But it always would backfire when I would shift from 2nd to 3rd on WOT runs. I know I need to check my timing, but last week I decided to run 91 in my car and it doesn't backfire at all now on WOT runs and the exhaust smells "cleaner" if that makes sense. But back to the compression... I've been reading up on compression ratio's. And at roughly just over 1000ft sea level atmospheric pressure would be about 14.2psi. So my compression of 155psi divided by the atmospheric pressure would come out to a ratio of 10.915 rounded to 10.92 or 10.9:1. Does that sound about right? Stock ratio is 9.5:1 correct? This comes from a theoretical thermodynamic equation. Psi readings from a compression gauge are related to compression ratio so this has to be fairly close.
So, with all that, does my gas issue sound like it solves my problem because I have raised compression? Maybe its not a timing issue at all?
What do you guys usually get in psi a stock engine using the compression tester? What do you guys get in psi that know your compression ratio?
