1 - 20 of 36 Posts
KILLER
IIRC from when I did my blower install, 05-09 Thermostats had an issue that was fixed with the 2010. I think replacing with a 2010 unit is the fix.. Not 100%, but worth looking into.
Extraordinary Posterior
O'reilly......could that be the problem!? Maybe I will look into getting a 2010 thermostat........are they the same size??
Carport Built
I ve bought a 2 fuel pumps from their and neither worked right out of the box. Sometimes you just get a bad part,
KILLER
From 03-2010 they are all the same size, But the OEM Ford one had some issues I think. When I was installing the manifold for my blower on my 2010GT, the manufacturer of the manifold suggested that anyone with a 09 or below should replace the thermostat. I'll do alittle research and figure out why...
Also, how do you know its bad? Whats happening, overheating?
Yeah, it was overheating.....also the hose below the thermostat would stay cold, even at operating temp. I took it out and heated it up and it didn't open.
I work at Oreillys ****ers lol
But the parts are different. Never will they be factory parts ..... Just letting you know so some of the parts don't function the same..... Goodluck
I always drill a 1/8" hole in the thermostat flat so there is always a flow. That will help with overheating in the event it sticks closed at a less than convenient time.
Did you install it facing the correct direction?
Discussion Starter #13
:lol yes i did. the first time i did it 6 months ago i didn't :facepalm: but then i fixed it right after......so yeah, this time i did! :)
3v reppin'
Get a fail safe thermostat so at least if it fails, it locks in the open position.
Discussion Starter #19
A fail safe thermostat sounds interesting...Ive never heard of such thing, it makes sense tho. If it goes again I will look into something else. But they only cost a few doll hairs so its not like it broke me or anything.
Like A Boss
Yeah, as far as bad parts go, when I bought my car, the throwout bearing (which is hydraulic) was really noisy. FYI, Hydraulic TOBs don't go bad... so, maybe your thermostat(s) and my TOB were made on monday and/or friday
1 - 20 of 36 Posts
