1 - 19 of 19 Posts
Im sure it has been asked a million times but i can't get an exact answer... I was having problems getting me car to look good after i washed it but maybe even more since I had it detailed. I wash it in the shade with a bucket and sponge. ICE 2 in one clean and shine solution and it seams to leave a soap residue, almost worse than before i washed it. It seams no matter what i do i can not get that shine, always hazy. Worst part is it's a black car, so it really shows! Help suggestions. I even just went to one of those spray yourself washes and used the power washer soap and rinse still same problem. The only way i get it to look half way decent is with a quick detailer after but that takes forever!
It'll buff out...
Sounds like you're using a soap with wax in it. That would mean you'd need to buff all the residue off with a clean dry microfiber. You're using microfibers right? If you have cheapo ones get some good ones from autoality or chemical guys, you'd be surprised how much of a difference it makes in buffing off residue. I'd recommend using a soap with no wax in it, basic wash soap. I dry my car a good three or four times after I wash it to get any streaks or residues off. Pooling rinse, leaf blower, microfibers with qd, dry microfibers and done. Black is tough because it will show everything, but just try using a clean dry microfiber and buffing the haze.
Oh and btw don't use a sponge use a wash mitt, a sponge won't pick up dirt into itself like a mitt will, a sponge will get dirt on the surface, then you're scraping it all over your car.
Sent from AutoGuide.com App
I would use a wax and grease remover from an auto paint Store, then buff and polish.
00blkvert
I agree with Stevey but I don't think it's as much of a soap issue, could be partially, but o think it's more of the soap drying on the car. I think you need to try it how Stevey said or as close as you can.
I also have a black car I pool it, blow dry it, qd/Mf towels, then hit inside all the doors, trunk etc, then I go and make sure there is no left over beads or runs anywhere.
Obsessed Detailer
Id get a different soap, always wash in the shade and be sure to rinse very thoroughly and keep the car wet when you are washing.
If you are still having hazy issues and you feel that your paint needs more depth and gloss, it may be time to look into polishers :yes
That Regular Guy
I always wash around sunset for my personal car. Customers I have all day so that's not an option. But it takes me just enough time from when the sun goes down to pitch black to get her all washed up
Obsessed Detailer
You got it^ lol.
The kind of paint protection you use plays a large role in easy of wash and drying too.
who sells the best mf towels? I need a bunch more I've only been working w/ 2 I have a bunch of shop towels but they leave fibers everywhere.
---------- Post added at 03:41 PM ---------- Previous post was at 03:38 PM ----------
I also need a good wash mit if you can recommend one.. the one I have is from walmart and its starting to fall apart. (washing the wheels pulls out the fibers)
It'll buff out...
Autoality.com
Detailersdomain.com
Chemicalguys.com
For microfibers.
NEVER use a shop towel on your paint.
The carpro wool wash mitt on autoality or DD I believe, is really good.
I just use a microfiber one from advanced, it's really not that bad but I need to upgrade lol.
Btw, dont use the same mitt you use on the wheels on the paint, wheels are always more dirty and have brake dust on them, you don't want the possibility of brake dust rubbing on your paint. Invest in two buckets and two grit guards to rub the mitt on to get the dirt off.
my paint is pretty poor atm I plan on getting it painted at the end of the upcoming winter so I wasn't too worried about only having 1 mit, just want to start building up my kit little at a time starting with the small things, by the time my paint is worth keeping pristine I will have everything I need.
Obsessed Detailer
With MFs, Edgeless or silk edge are both fine, i dont think edges really help hold shape or anything IME, lol. Beware of tags, most good MFs come with stickers on them or tags that are designed to be pulled out. Just my .02
PERP! I wast that mitt! Gonna get it soon i think and dedicate the Merino to clients.
Discussion Starter #15
Thanks for the info i think maybe since my car has a good wax on it from being detailed and i am using a 2 in one wash / wax that may be the problem also I did switch from mitt to sponge guess ill go back to the mitt see how that works! whats this about grit guards and two buckets though?
It'll buff out...
The two bucket wash is the standard washing method most detailers use to reduce the possibility of causing swirl marks or marring. Go on YouTube and type in two bucket method, watch the junkman2000 video he explains everything and shows you
Obsessed Detailer
The wash n wax shouldnt effect the haziness youre talking about. If u rinse the car properly before the soap dries on the paint then you should be fine.
Next time you wash, if u get haziness, go over the car with a Qd, id that doesnt work, try a clay bar or cleaner wax and see if that helps you.
If you dont already, TBM like stevey said.
Discussion Starter #18
Well what else could be the haziness... I had someone go behind me and rinse as i scrubbed same crap! Also forgive me but what is a Qd, maybe it has something to do with the water here in Texas... Never had this much of a problem in Florida! good thing Im going back there in 3 weeks!
1 - 19 of 19 Posts
