421 - 436 of 436 Posts
Discussion Starter #421
well guys its finally time for a real update, here are some pics from the last few weeks
got the retro rings in the cluster
e brake broke again, time to rip it out to weld
tear down has begun, wonder where the vac leak was ? lol
new valve covers mocked up
ps pump off to clean
timimg cover off to clean and paint
found one of these things
mocked up
cleaning up the lower rad support
how the motor sits now
bumper support shimmed to fit intercooler
old longtubes
sold to a fellow member
new water pump
tma headers
custom rad cover
PTP blanket
and thats been the last couple weeks, moving along slowly, hoping for start up in early june.
Discussion Starter #423
Nice progress, I am pretty jealous of those valve covers lol. I do want a set, so expensive though!
there is a set for sale on here for $150, i found mine used for $100 a couple years ago. Finally putting them on lol.
Discussion Starter #424
Well almost three years to the day this thing is up and running. Ignore the air filter lol. That was temporary. More updates to come.
Sent from AutoGuide.com App
Discussion Starter #426
Nice work, looks good! Post some videos!
What ever happened to the turbo stuff I send you?
Videos will come, and I ended up selling it to a local guy, still have the oil pan and all the accesories though.
Discussion Starter #427
not an update just some pics from along the way continuing from the last post with pics.
bumper support taken off
intercooler roughly mocked up
support shimmed out to allow intercooler to go between it without any cutting
timing cover was throughly cleaned and painted wrinkle black with high temp clear
engine block also cleaned and prepped for same paint
spare water pump and timing cover used to help mask
tapping pan
pass header in
drivers header on
the ac bracket and power steering bracket were also cleaned and painted to match timing cover
intercooler brackets welded to bumper and foam support trimmed the same thickness as the spacers, then fastened with large zip ties
bumper test fit
the stock coolant crossover was very close to hitting the throttle body with the windstar intake manifold, cut it down to tap a new fitting on but ended up cutting too much, welded a little back on and drilled/tapped for a brass bleeder valve.
piping
not sure why it is stepped the original TMA kit must have used a 2.5" intercooler
working on maf location
flange welded on
e brake hopefully fixed once and for all
little more progress
working on modifiying the crossover to fit, this was a major roadblock. I was not expecting to need to do this.
electronic boost gauge T and trunk battery wire
vented can mounted
new overflow
Next major problem is the virtually no clearance for a fan between the turbo and rad, this was a result of the crossover not fitting and me not having hotside fab experience and this was a little bit of an oversight
downpipe mocked up, but thats as far as she went, wouldnt fit the next piece of pipe so that was the end of that for now
I was so mad at this point I said **** it and dropped everything for over a month and drove to the American Muscle show in PA for a much needed vacation.
got home and it sat for another couple weeks and then I got it together just enough to get it to my buddies shop so he could make the crossover fit better and finish the downpipe
I had the downpipe kind of hacked up dumped in front of the wheel as a temporary thing which led to ripping the powersteering line twice
test drive to work
and as soon as i got home after fixing in the parking lot at work
finally back from the shop in November
ignore the temp filter
Discussion Starter #428
here is the final result of the spacing, Im not sure if this slim fan will be enough to cool it in the summer but time will tell
she is now parked for winter with some light mods coming in the spring with the main and really only goal of getting this thing to the 14 AM show and MM cruise
HKS boost conroller and wot box to be installed
04 cobra fuel tank should ensure no fuel issues for now
Will be adding methanol injection to all that, a water temp gauge and maybe two smaller higher flowing rad fans, get it on the dyno, some window tint and that should be it for this car.
Discussion Starter #430
do you think it is easier to run the downpipe out the drivers or passengers side ?
drivers side IMO, there are fuel lines and AC lines on the passenger side, not to mention the AC expansion port, and Im sure Andy would have built his kits that way if it were easier.
Discussion Starter #432
picked up a stock motor to slowly build up
mostly torn down
also got my gauge mount in
Ill have to cut out a hole for the EVC to make it sit flush with the gauge on the left which is going to be an aeroforce interseptor
Discussion Starter #433
time to bump this up
Will start posting some real updates
cliffs
351w
full 1995 GT wire harness swap - car will become a 1995 GT in a 2000 shell
megasquirt
CG fab hotside
tko600 or t56
stay tuned
Discussion Starter #435
Discussion Starter #436
Picked up a 351 roller block. Brand new trickflow track heat upper and lower. Getting a set of freshly rebuild e7 heads for free this weekend. Will probably just sell them and put the money into the build.
