ok so i have some pretty bad spark knock after i installed the m112. what things do i screw on my xcal 3 to stop the spark knock?
If you don't have the money, I suggest you not screw around with anything, otherwise you will be building an entire motor. And if the car is knocking, then you may also not want to drive it otherwise you may end up building an entire motor. What injectors, and fuel pump, and boost are you running? Did you at least get a base tune from VMP/TrickTuners?i no i need a tune but i wana get a camshaft first. and i dont have to money right now for that so i was tryin to see if i could screw around with something so the spark knock went away
nope. how much are those? and im running 42lb injectors with the 310 lph pump and boost i think is like at 8 or 9? idk when i hit it i never really looked
