1 - 17 of 17 Posts
what plug would be best for my 2000 gt 550 comp cams bbk headers and intake? kinda new to the modulars!! thanks
i just seen in your sig that you are running spray. if this is the case you want to run 1 heat range colder.
here you go
MOTORCRAFT
AWSF-32C / stock heat range - copper plug
AWSF-22C / 1 Heat range colder - copper plug
AWSFA-12C / 2 Hea range cooler - copper plug
AGSF-32C/ Recommended for FRPP heads(not sure on heat range)
NGK
TR-55/ 3951/ Stock Heat Range
TR-6/ 4177/ 1 Step Colder
BP7EFS (PN - 3526) BR7EF (PN - 3346) two steps
R5724-8 (PN - 7317) two and a half steps
R5724-9 (PN - 7891) three steps
R5724-10 (PN - 7993) four steps
AUTOLITE
764s / Stock
103s / 1 heat range cooler
AR94 / 2 heat range cooler
AR93 / 3 heat range cooler
AR92 / 4 heat range cooler
CHAMPION
YS-59C / -3 or -4 below stock heat range
DENSO
IT16 / stock heat
IT20 / -1 heat range
IT22 / -2 heat range
IT24 / -3 heat range
here you go
MOTORCRAFT
NGK
AUTOLITE
764s / Stock
CHAMPION
DENSO
IT16 / stock heat
and he delivers yet again!! :D
wraith....gonna have to get up with ya when i come back to VA Beach man....gonna hit you up for some advice on some stuff if your around and not too busy.
well, that spark plug list is in the sticky ;) as for best, its a personal preference. for your spray, go with a one stage colder and brand of your choice.
:) I got somemore stuff if you want to make a sticky. How to install and time 4v cams from the FSM, Comp Cams, and Sean Hyland. Let me know.
yeah bro, not a problem just let me know. Ive helped out a couple of guys from around the area.
mm's nitrous mod
i was thinking about doing some stuff like that with pics from one of the motors i have done.
1 - 17 of 17 Posts
