1 - 6 of 6 Posts
Hello,
New to the site Tons of info here. My Question is I am still runnin stock plugs but with my mods was wonderin if they are enough? Thank You
Discussion Starter · #2 ·
ANYONE? I know that someone has a suggestion.
Doc
welcome to the forums.
you are going to want to use a colder plug if you are using nitrous.
esp that big of a shot.
Billy Weston
run Autolite AR103 they are cheap, better conductor than platinum or iridium and most of time will melt before your piston does when detonation occurs.
Thanks for all the info. The motor has about 5,0000 miles on it the car has 100,000 the dealer screwed up and gave me a 60 day warranty on the car when I bought it 2 months ago so when I got it home it had a small oil leak and after looking at it the block was cracked just above the oil filter housing. So they put a new motor in. Got lucky! :eek: I think I'll try the autolights
1 - 6 of 6 Posts
