Okay, I had an intake hose from my throttlebody down into the intake that got cut. I didnt notice it right away, it was sucking air out of the enginbay down into my intake. Within that weekend my car started to idle bad(how I noticed) and I lost some perforemance. I thought it was the tube causing my car to not idle right and just run lean. Fixed the tube.
I still have my idle problem, sounds like a missfire, Im betting some crud got sucked in and is now clogging a tube or sparkplug. What should I used to clean out the tube if this is the case? Or is my plug just damaged and need to be replaced? I checked wires and everything, everything seemed good.
Need some suggestions before I just Replace my plugs and call it even.
