1 - 20 of 20 Posts
Location (city, state):Orlando,FL
Items being sold:SPEC FLY
Price:$225 Shipped
This Flywheel is as good as New.
Flywheel is in Great Condition with only 1,250 Miles of use on it.
PART #SF64A
New From AmericanMuscle $334.99
SPEC Billet Aluminum Flywheel - 6 Bolt (96-98 and Mid 01-04 GT) at AmericanMuscle.com - Free Shipping!
Product Description
If you want to squeeze all of the horsepower out of your Mustang that is possible, this is the flywheel to go with. Lighter weight than steel flywheels, This Billet Aluminum Flywheel is designed to get you reving up faster and reduce drivetrain loss, resulting in more horsepower to your rear wheels, just by reducing the amount of rotating mass and force it takes to get the flywheel turning. Some times resurfacing your flywheel costs as much as getting a new one, so why not buy something that will give you a performance boost!
This SPEC Billet Aluminum Flywheel is the perfect companion for your new SPEC Clutch. CNC machined to an unheard of .001 tolerance (the industry standard is .010), this flywheel is designed to have perfect balance and the best surface for bedding with the new clutch, and is also SFI certified.
All SPEC units are rebuildable and feature a replaceable steel friction plate that is made from a friction-enhancing steel metal specially formulated for optimum clutch bedding and holding power, so this just might be the last flywheel you will ever have to buy!
This SPEC Billet Aluminum Flywheel is designed for the Mustang GT's with a six bolt main. 2001 Mustangs with production date after 01/01 have a six bolt main. Please check with your Ford dealer to determine if you have a 6 bolt or an 8 bolt main.
If you still have this next week when i get my taxes back I'll pick it up from you.
Discussion Starter · #12 ·
did it sell?
1 - 20 of 20 Posts
