1 - 7 of 7 Posts
Was just curious if someone had any info on the gains after a PI swap on the 96-98 models.
  • Like
Reactions: AndrewA.
mm's nitrous mod
depends what all gets done during the swap. people are getting 100rwhp with worked pi heads, cams, and header back.
i would say 40, since the 96-98 has 220 hp, and the 99-04 pi has 260. but maybe less, because your motor has more wear on it then ours.
A full PI swap on the npi motors has been known to give around 45-50ish rwhp. Your compression will be raised which is why a PI swapped npi engine will put down a few more hp.
the people with increase of 100 rwhp are useing custom cams, and not PI cams.........
with worked heads alone u'd prolly only gain about 50-60 peak rwhp, but with a good head/cam combo u can make close to 300 rwhp with an exhuast and tune
Its 50-60 with a Striaght PI Heads, Cams and Intake. Assuming you have some exhaust mods. You throw on a stage 1 or 2 cam. And your up to around 300 whp. So 20-30 more than with the PI cam. Your also looking at rougly a 1 point increase in your compression ratio, pushing you to use premium gas. not required, but definitely recomended. Now a custom cam with full exhaust and new TB & Plenum, you can be up to 340. But its all in the tune and cam grind.
1 - 7 of 7 Posts
