i just put some 3.73's in and now the speedo is about 10mph off, what do i need to do to fix that?
Manual or automatic?would u mind putting up a lin to one, so that i know wt ur talking about?
It's on the drivers side of the tranny about in the middle, just look for the speedo cable you can't miss it.its a manual 5 speed, ok so were is this supposed to go? inside the tranny? or is it at the rear of the tranny were the drive shaft slides in?
Once you find where the cable goes into the trans you will see a 10mm bolt that holds a clip to hold the speedo cable in, take off that clip and pull out the cable you will see the gear on the end of the speedo cable that you are going to change. Take off the c-clip that holds the gear on and put your new gear on and put the c-clip back on and do reverse to reinstall the cable.does it go onto the line or inside the tranny?
