1 - 13 of 13 Posts
Don't know where my origional thread went to but here it is again.
at 1 mph before a stop and after a I take my foot off the break to go I get a slight bang or hard shift. I was told a great meny things like a jmod, a shift selonid, a1-3 shift selonid, dry slpines in the drive shaft or something in the differential. I have the 4w70r autimatic tranny on a 2000 v6 convert.
Has anyone experienced this problem? All the suggestions seem plausable but I'm no mechanic. Don't want to get robbed. If I have to do it process of elimination where do I go first, second, third.......
Thanks
MM's Resident Ricer
tranny specialist and have it diagnosed, and check your fluid level
Thanks for the above info.
Changed the tranny fluid twice- no metal shavings, real clean. Changed filter twice also.
Is the u joint check an easy one to do?
Doc
very easy.
put the car in park and get under the car.
try and turn the drive shaft by hand.
if it has more than a half of inch play in it you need u joints.
yeah ppl these days... like my friend tried to shift w.o pressing the clutch :wtf
doc idk ur avie is.. different..
1 - 13 of 13 Posts
