1 - 4 of 4 Posts
Just got an 02 GT, 5 speed for my wife. I have a set of HR springs from a fox body and a new 8.8, 3:73 Posi rearend for a fox body. Will the springs and rearend fit the 02?
thanks
They are not the same width. 3/4" narrower on each side. Will fit though.
have you converted the fox rear to disc and 5 lug?
you will also need to drill out the LCA bolt mounting holes to a larger diameter (19mm IIRC)
to fit the larger bolts used on 99+
and as mentiond it is narrower so spacers will most likely be needed unless you had wheels with the proper backspacing
1 - 4 of 4 Posts
