1 - 11 of 11 Posts
Get Maximum Motorsports brand spring isolators, they're the thickest ones out there.
.69" thickness front (.25" top, .44" bottom)
.56" thickness rear (.18" top, .38" bottom)
Solid urethane
That's almost an inch at the fenderwell (lever effect of the control arms) over not running isolators at all, and a half inch if you kept the stock ones in.
Anandavenkatakrishnan
I'm so confused right now. What's your question?
Priest of the Car Gods
He doesn't have one; he's telling people that if they put springs in that dumped them too low, they could get the car back up by swapping to MaxMo isos rather than having to change out springs.
:facepalm:
I know the front ones were around $25 a little while ago.
Disturbin' The Peace
If the rear is low, then lower the front more to make it look right
Discussion Starter #9
  • Like
Reactions: Nito2v
Pays in respect
Reps++
This could solve my H&R's being too low issue if that happens. Gotta install them first and see how it is. If it's too low I will pick these up.
Discussion Starter #11
Reps++
Mine were OK with just an X pipe, but when I put the longtubes on I needed a way to make up the difference without buying new springs.
1 - 11 of 11 Posts
