Hey guys so I just spun a rod bearing a while ago and wanted to know where would be a good place to buy a new set? And also what else should be replaced while the oil pan is off?
thisForge it.
I do plan on it but I will be buying a forged short block, where Sid you get the bearings?If you spun a bearing (which I did a month ago) your crank is going to be toast. If you have any plans of making over 400hp you should build the motor while it's down.
Not always, they often can be salvaged, but will need to be reground/polished, and use an oversize bearing.If you spun a bearing (which I did a month ago) your crank is going to be toast. If you have any plans of making over 400hp you should build the motor while it's down.
Yea my buddy told me he has done a couple where he just replaced the bearings, I heard the noise and drove home about 5 miles and parked it, my buddy's going to be looking at it tomorrow so hopefully everything turns out fineNot always, they often can be salvaged, but will need to be reground/polished, and use an oversize bearing.
I had a friend that spun several bearings in his car, and did that all without even pulling the motor. He dropped the K and the oil pan and just went to town.
