1 - 7 of 7 Posts
Replaced my rear shocks recently with no name brand OEM shocks now about a month later my rear end makes a squeaking sound when i push down on the rear end?
I dont hear it when i drive mostly just when i am getting out of my car and the suspension lifts or when i push down and let it bounce back up.
any ideas would be great.
MM's Samsquanch
did you just do shocks or did you do the springs at the same time? do you have spring isolators in the rear?
could be the control arm bushings as well
Sarcastic Sally
I could be wrong, but cant new springs make that kind of noise for a bit until they get broken and firmly seated in?
possibly if there were new isolators used but with it only being a shock change I'd say it's most likely a control arm bushing, mine did the same thing until I changed them out actually. If you get some white lithium spray on grease and spray the bushing on both sides between the mounts it should quiet it down for a little while, and you''l know what the problem was. also check the torque on your lower shock bolts just to be safe
Alright cool. it hasnt been bad lately so i kinda forgot about it but it is still there. and it was just my shocks i replaced. i have BBk lowering springs they are couple years old. and for the isolators i have no idea. never seen them never touched them hahaha.!
1 - 7 of 7 Posts
