1 - 10 of 10 Posts
Old timer
My car lately has gotten a real bad squeak from the right rear area. Its only when I turn my car to the right, but even a slight turn will do it. Its driving my ****ing crazy. The faster I go the faster the squeaking gets. Any ideas?
N/A 4v Guru
Have you pulled the wheel and inspected the caliper and heat shield? Make sure nothing is loose or rubbing. If its not there I would bearings after that
When I put my new rear shocks in they squeak everytime I go over a bump real slow or make turns real slow and hitting little or big bump. Someone on here said it might be the rubbers they used when they installed it. Maybe your having the same problem? This would be my guess if you have changed anything back there.
this is doubtful if it's constant squeaking, but it could possibly even be your exhaust clinking against the car body...ever since I put in my new exhaust and i hit some bumps i can hear it hitting something
1 - 10 of 10 Posts
