1 - 3 of 3 Posts
hey guys, ive got a p1sc on my gt and ive recently changed my power steering pump due to it dripping on my belt. Not long after it was dripping on the belt there started to be a squeaking sound near my idler pulley. The belt is clean as new now and theres still a squeaking with a cold start up for about ten mins and squeaks wen i get on the throttle at higher rpms. im gunna change the belt probably today but has anyone else had this problem? Im kinda thinking it might be the idler pulley though..
You need to find out which pulley it is. I think WD40 will work. Sence your changing the belt anyways, before you change it, have the car started up, make sure its squeaking and isolate each pulley. Try the idlers and tensioner first.
Mines squeaking too, My belt is to tight for the setup, so I need a new tensioner. And bigger belt.
1 - 3 of 3 Posts
