Sounds like your wiper or rubber trim is starting to dry rotten and what your hearing is the hardening rubber gasket creating friction between it and the window. I would suggest replacing the gasket or treating the rubber with silicone or similar product as suggested. Make sure you pull the rubber lip away from the window to treat where the rubber and the window meats.
