1 - 10 of 10 Posts
From a cold start it fires right up, but once the engine gets warm them it wants to act like a low battery
What could cause this?
Could be your starter either on its way out or getting too hot. The starter is right next to the header and some people wrap their headers for that specific reason, to keep the heat off the starter.
Well either suggestion leads to something suckin, distributors are freakin pricy and starters are kinda a bitch 2 change
Doc
^ cold starts my cougar would start fine.
hot starts... about 15 tries later.
turns out ( i recently replaced the distributer and jacked the timing by 2 degrees)
the timing was off.
I corrected the timing and it starts fine.. so I guess I"ll go with bad timing. lol
Your starter is probably going bad. They work ok when cold and not ok when warm. Very common. You could be shortening its life if it is close to long tube headers.
HMUSN, 2 degrees difference kept your car from starting when warm and it was acting like a low battery? I would have never thought of that.
wrap that new starter. Heat is terrible on electronic parts. Cold actually makes for a better conductor of wire.
1 - 10 of 10 Posts
