1 - 5 of 5 Posts
i just re relocated the battery back into the engine bay from the hatch cause i thought maybe it was a bad ground..nope.. i can get the starter to click with a screwdriver on the solinoid but it wont turn over i think my battery doesnt have enough juce so its charging. i just bought a new solinoid so its not that i think the wire that causes it to switch over is bad...is the wire that causes the selonid to switch over and send power to the starter a power wire?
all motor
is the starter good? run wires from a battery to the starter bypassing the ignition/etc and see if it works properly
the starter worked fine when i bought the car i think its cause the dead battery why it wont turn the car over the problem i am having is i cant get to turn over with the key i have to use a screwdriver on the selonid
¡ʇsnq ɹo uʍop ǝpısdn
did you try given it a lil jump to see if that would turn it? ... just a though ... but batteries can die beyond belief... hopefully a charge works
1 - 5 of 5 Posts
