1 - 7 of 7 Posts
So some times the car starts and sometimes it doesn't. Sometimes I can drive and start it no problem and other times it will run for a couple minutes then die and not want to restart until it sets for a few minutes. What would the most likely culprit be? I don't think it is fuel I think it is ignition related because I do smell gas and hear my fuel pump. TFI? COIL? PIP? Please let me know what you guys think. Tired of having problems trying to go to work or get home lol.
That's the thing. Sometimes it hasn't even had the chance to warm up. Like today leaving work. It was probably in the low 60's out and it had only ran for about 2 mins when it died. Fired right back up and I made it maybe a 1/4 mile and it died and didn't want to start. Give it about a minute and it cranks right back up only to die in about 30 secs. Finally get fed up and tap on the tfi and the coil and still nothin so I sit for a second and crank it up again and it drives home with no evidence of a problem. Could go out in the morning and I won't have any idea what it will do. Might run and get me to work no prob or might start then die and not start back up like it occasionally has been doing.
Get your TFI checked first at a local auto parts store. But this sounds like a TFI for sure. You won't need to remove the distributor all the way either to get it out. just remove the cap, loosen the hold down clamp, unplug your slid connector. and turn the distributor. You will need a thin wall 7/32 deep socket to get the TFI out too.
1 - 7 of 7 Posts
