Dude, I know this is probably a stupid question...what's your plug gap? And what would you ask for the whole car, should you sell it?
gap is at .028". If I sell probably $20k that would get me money back on trans, rear end and shortblock.Dude, I know this is probably a stupid question...what's your plug gap? And what would you ask for the whole car, should you sell it?
no codes are showing. I'll check that when I change plugs.what codes are there??? i had the same issue two days ago and it ended up being the lower plug in the pcm wasn't all the way in. pulled it out cleaned it up and pluged it back in and everything is fine now
I'll check it tomorrow when I get new plugs installed. I'm not sure on fuel pressure either, I'll have to datalog it.When it is parked does your fuel pressure bleed off real fast? It sounds like it's flooding for some reason, maybe a sticking injector. Next time when it won't start pull a coil off and check for spark too.
Damn it. You're going to be in the 9s...before me. NPR is back open.heading to TPS this morning
