1 - 20 of 24 Posts
So recently did some more upgrades to my 06 im at this hump that i cant get over. If i knew the car was running the correct mph i would be fine with running 13s but im trying to get into the 12s. I simply cant get in. The car runs pretty consistently 13.1 to 13.5 depending on my hook. My problem is that it will not exceed 105 to 106 mph. This car should be running 110+mph imo. Well today i had it. Was running 13.3 to [email protected] 106 my 60 foot 1.9. I drove my good friends 99 cobra just lts x pipe catback tune and 430s ran a [email protected] ive had it. What am i doing wrong?
imrc deletes
gt500 tb
127200s
410s
pypes lts
x pipe borla xb
C&l Racer
tune from bbr i use to run a dyno tune from st motorsports. That tune netted me the highest mph.
1.9 60' 12.8 @ 109 on stock rims, tires and stock converter
UDP
127200
LCAs
C&L street CAI
Lts
O/R X
Stock Muffles
CMDP
4.10's
Tune was from Brenspeed.
It ran like a bracket car, solid all day long.
You might need to data log to get someone to look it over
UDP
127200
LCAs
C&L street CAI
Lts
O/R X
Stock Muffles
CMDP
4.10's
i Just ordered a tune from brenspeed today. lol Hopefully they can get it to me before next week. It doesnt feel like it runs slow but it is lol
---------- Post added at 07:10 PM ---------- Previous post was at 07:09 PM ----------
Auto or manual?
all 5 speed manuals.
Insomniac
Take video of your next run inside the car. Before i did i didnt realize i was shifting too early and was coming out of my power band. Make sure youre running the rpms out to 6700 or higher. Heres my video for reference, you can hear the bog in 3rd.
https://youtu.be/4jLWZslQS2g
i always run mine out to 6700 rpms
My peak power is 6300 dyno was 345whp on a dynojet. Im about to go back to stock cams. i was running 13.2 to 13.5 with just intake tune h pipe. lol
Discussion Starter #10
exactly makes no sense. Im getting super frustrated. I know its not my driving because that 99 cobra i drove today i went faster then my friend in his own car....
Resident Headbanger
Hmmmmm maybe the tune? Could be super conservative or cam timing retarded.
I don't think so 'cause his engine isn't lacking for power with 346/325.
Could just be the air, maybe a strong headwind, and the DA does make a big difference.
That said, most of the power is concentrated above 3500rpm so he may need to launch at higher rpm to get away quicker. Having 4.10s in the rear also means he has to shift into 4th before the 1/4 mile trap and that could also be slowing him down.
Discussion Starter #15
Well i had 373s before but ran thru 3rd gear same mph 105-106
I am crossing the traps in 4th at almost 6k now. But how am i running so much slower these times are on the same days as others bolt on 3vs running 110. I havent driven onebut they pull on me after the 1/8 mile
Have you thought about trying a bigger tire? I gained in my ET going to a smaller tire but I lost on my trap speed. Used to do 117-118 with the 29" tires. On my 28's I run 116-117 but like I said, my ET is quicker by a tenth or two.
And I don't see anything as far as suspension mods. What tire are you running?
from other threads...
Also added some suspension upgrades wont get into that right now
Yea my car is heavy to. Full weight premium with shaker just spare tire and jack removed. I need to weigh it tho.
yeah i need to run lighter tires. Ive been running 34lb 19 inch 2010 gt500 wheels and 285/35/19s out back.
- what suspension work has been done, and how is it configured?
- remove as much weight as you can, every little bit helps with an N/A car (shaker sub/amps, pass seat, rear seat back/bottom, front sway bar, etc. it all adds up).
- those heavy wheels and low profile tires are doing you zero good at the drag strip
- what RPM do you launch at?
But how am i running so much slower these times are on the same days as others bolt on 3vs running 110. I havent driven one but they pull on me after the 1/8 mile
maybe they have their suspension/tires dialed in for the track?
my first 1/4 mile pass back in the fall of 2013 (right lane in time slip pic) I had UCA/LCA,LCA relo brackets, cobra jet springs, strange single adj struts/shocks, 17" m/t bias ply rear tires on OEM wheels and a gutted trunk. K&N CAI, frpp shorty headers, OEM h-pipe with cats, steeda UDP, 93 dyno tune putting down 302rwhp/317rwtq on a dynojet
Discussion Starter #18
Im running a 26" tall nitto nt05r
I have ran a 28 tall mickey thompson and that one netted highest mph 107
There you go. Run the MT's and watch your trap speed increase.
Insomniac
I think he lacks the hp and mph to really benefit from a 28" and hes bringing the 4.10s down quite substantially. I say keep working with 26" but move to a bias ply tire.
1 - 20 of 24 Posts
