1 - 1 of 1 Posts
2 JEGS Sport Star 5-Spoke Wheel Diameter & Width 15 x 10 " Bolts & Bolt Circle 5-4.5" Back Spacing 4.5"
These front end parts will give your 1999/2004 Mustang a 2003 Cobra stance, all have been installed, and were new at the time. They have less than 50 miles on them. They are The are Stedda springs, Bilstine shocks, and ford racing 2003 cobra lower arms. Come steal these parts from me! After we installed these parts the car design was changed from a street fighter to a pure race car. Some install wear on items.
2 Ford racing 03 Cobra lower arms
2 Bilstein struts: 395-V36-4138-“Heavy Duty” work best with Steeda Sport Spring sets, any of the factory V8 springs including Bullitt or Mach 1, or any other spring in the 550-650 pound range.
2 Stedda Two Steeda Sport Springs -223-9004 - 03-04 Cobra fits all 99/2004 Mustangs: Lower the car 1” to 1 1/4” Spring rates 650lb front, Big improvement in handling and looks Maintains good ride quality
1 Heavy Duty Steeda Front sway: Full 1.375" diameter for superior handling, flatter cornering and better stability. Steeda's 555-1087 bar is four pounds lighter than the stock 1987-1993 sway bar and lighter than most other aftermarket sway bars. Swaybars come with new polyurethane pivot bushings.
Note: Steeda Swaybar Spacer Kit required on 2003 & 2004 Cobra Mustangs
2 Steeda Billet Aluminum Front Swaybar Brackets: A common suspension upgrade for Mustang owners is a high performance front swaybar. Yet when you re-use the factory stamped, strap-type brackets to attach that beefy new bar, you never get the full benefit of that upgrade due to excessive flex in the steel original. These billet aluminum swaybar brackets eliminate that weak link.
By more positively attaching the swaybar to the front sub-frame you minimize compliance roll and permit the bar to more efficiently reduce body roll through the turns. More precise, stable handing is the result.
2 Steeda Heavy Duty Front Swaybar Endlinks: Replace your factory endlinks with these upgraded links from Energy Suspension. These endlinks are stronger than the original links and feature high quality urethane bushings, zinc plated nylock nuts, and heavy gauge washers. Endlinks are a direct bolt on replacement.
500.00 OBO
PM me if intrested and will provide pics
Located in Pensacola FL
Will accept Pay-Pal
SOLD AS A COMPLETE PACKAGE!!!!!
1 - 1 of 1 Posts
