Yeah but like I said I'm comparing it to when I had bad ball joints. The bumpsteer kit lines up the tie rod with the control arm a lot better.does it make your steering alot tighter or...?
I did the same except I used Prothane bushings for most and aluminum in the rack.i thin you would get a tighter steer from polly rack bushing and polly controll arm bushings ,, do them while you have it all apart ,, when i did mine i used the moog balljoints they are good quality and i did Energy Suspension controll arm, rack an pinion ,strut tower and coil spring isolator bushings all at the same time and wow! made a massive change in how it drives
