I was hoping someone could provide a little advice. I just installed long tubes on my car.
I put in new mounts and bolted up the k-member. For the life of me I can't get the rag joint to go back on the shaft.
I know it's keyed ... I assume the notch goes where the bolt threads through. I locked the column before I started, but the shaft must have rotated slightly.
Anyway, I unlocked the column and rotated it 360 degrees and I couldn't get it to go over the shaft.
Getting in there with a hammer is going to be next to impossible, especially with the header in place.
Any advice would be greatly appreciated.
