Status
Not open for further replies.
1 - 3 of 3 Posts
mm's nitrous mod
BRAKES
http://www.moddedmustangs.com/forums/99-04/194743-upgrade-brakes-speeding-up-slowing-down.html
ENGINE REMOVAL /REPLACEMENT
How To: Remove engine
How To: Mark VIII engine swap
ENGINE MODIFICATION /REPAIR
Forced Induction (FAQs) & Turbo/Supercharger Basics Pt.1
How To: Understand nitrous and effects of installation
How To: Understand supercharger and effects of installation
FI (FAQs) Pt.2
FI (FAQs) Pt.3
FI (FAQs) Pt.4
How To: Build affordable super-charger
How To: Understand beyond bolt-on upgrades
How To: Degree cams
How To: Assemble bare PI heads
How To: Install V-1 T-trim with FMIC
How To: Enable full-throttle cable adjustment
How To: Clean the AIC
How To: 2V to 4V COP Swap
How To: Install Airaid intake
How To: Exhaust system upgrade
http://www.moddedmustangs.com/forums/99-04/237573-how-compression-check.html#post4056680
TRANSMISSION REMOVAL / REPAIR
How To: Replace your clutch
How To: Tailshaft lubrication mod
How To: T-3650~T-56 transmission swap
How To: Auto to manual transmission swap
REAR END REMOVAL / REPAIR
How To: Compare 3:27 vs. 3:73 vs. 4:10 rear-end gears
How To; Installation new rear end gears
How To: Understand fuel use with new gears
How To: IRS to SRA swap
How To: Fuel pump wiring upgrade
How To: Fuel tank filler gasket replacement
SUSPENSION
How to install coils/springs
How To: Official Suspension Guide
How To: Un-Official Suspension Guide (companion to the ORIGINAL official Suspension Guide above)
How To: Replace struts
How To: Install Coil-overs
How To: Cut Your Stock Springs
How To: Reinforce Front Strut Towers
http://www.moddedmustangs.com/forums/99-04/155074-how-install-torque-box-reinforcements.html
How To: Choose a new tire
EXTERIOR / STYLING
How To: Seafoam
How To: Install hood-pins '99~'04
How To: Install cling-style tail light tint
INTERIOR / STYLING
http://www.moddedmustangs.com/forums/99-04/168046-how-install-raptor-shiftlight.html
How To: Repair lumbar support
How To: Install keyless ignition start button
How To: Paint interior trim pieces
MISC. STUFF
Test function on trip reset button
How To: 1/4 mile drag race tips
mm's nitrous mod
Discussion Starter #2
this is a sticky for power number's. the requirement for listing your power numbers is to pm me, futureMACH1racer, or lefty with your numbers, along with proof like a dyno graph or vid (vid must show numbers). if you would like to give you list of mods as well, add them in the pm and they will be listed as well.
jivepepper---------------00GT-----------665/540 centri (vortech)
BOB---------------------01 GT----------529/484 centri
UnixHH-----------------03 saleen--------470/440 centri (procharger)
Mustang46--------------02GT------------453/548 turbo
03 StangGuy------------03GT-----------448/405 centri
MATT02GT--------------02GT------------428/436 centri (procharger)
~C~--------------------00GT-----------370/380 centri
Eagle2000GT------------00GT------------370/377 centri (procharger)
Black Bullitt--------------01 bullitt-------366/382 centri (vortech)
SWEET2KSTANG---------00 GT----------364/462 n20 261/301 N/A
Bullitt5339--------------01 bullitt--------358/480 n20 263/302 N/A
GTRACER88--------------00 GT----------302/330 n2o 239/278 N/A
Jazzer The Cat-----------02 saleen--------245/285 N/A
mm's nitrous mod
jivepepper
Basic power list is:
Vortech V1 T-trim @ 20 psi peak
MMR MOD 900 Short Block
Patriot Stage 2 Heads
Houston Performance S292 Cams
TFS Intake with Oval Throttle body Upper Intake
Accufab Oval Single Blade Special Throttle body
Lots of support mods.
Mustang46
2002 Mustang GT
5.0 2v Stoker
70mm Turbo Kit 12 PSI Intercooled
Snow Performance Water/Meth Kit
60lb Injectors w/ Blow Thru M/A
Supercar Fuel Pump
75mm Accufab Throttle Body and Upper Intake
Full Tubular K-member w/Coil Overs
Complete Auto Swap w/full upgrades
BBK Shorty Equal Headers
Flowermasters
03 StangGuy
Novi 2000
Livernois 5L Stroker
AFM Power Pipe
Front mount intercooler
Accufab T/B and Plenum
Mac Pro-Chamber and Cat-back
~C~
*with out the o/r H pipe
~Procharger P1SC w/ 3.6 pulley
~42 LB Injectors
~SCT Big Air 2600 MAF
~SVT Focus 255 Fuel Pump
~Mac Off Road H Pipe
~Mac Cat Back Exhaust
~PowerProducts 75mm Throttle Body
~RPM UIP
~Centerforce Dual Friction Stage 2 Clutch
~BBK Adjustable Clutch Cable, Quadrant, Firewall adjuster
~BBK Sub Frame Connectors
~SCT Xcal-3 Tune by Woodbine Motorsports
Eagle2000GT
Stock 4.6L
ProCharger 8.9 psi @ 6000 rpms
ProCharger 3-core intercooler
42# injectors, SVT Focus Fuel Pump
Diablosport MAFia
BBK 75 mm TB/Plenum
BBK LT headers/catted x-pipe
Meizere Electric Water Pump
There are other mods but not related to power.
Black Bullitt
Vortech SQ-Trim - 366RWHP/382RWTQ @ 8.6#s of boost
AFM Power Pipe
Aftercooler and 3.33 pulley (Not Installed Yet)
sweet2kstang:
udp's, C&L MAF & inlet, 75mm t/b, ported GMS upper plenum, GMS coils, header back exhaust, tweaked canned diablo tune, 3.73's
100 shot NOS nitrous kit
GTRACER88:
CAI
Steeda Under Drive Pullies
Mac Long Tubes
Mac Pro Chamber Catless H
SLP Loud Mouth 1
4:10 Motive Gears
Dynotune Nitrous 100 Shot
Dyno tune at Houston Performance
Jazzer The Cat:
* 4.6 N/A motor
* JTL CAI & MAF 245hp/285tq
* steel-reinforced 8 quart Canton race pan
* T-56
* FRPP billet flywheel
* 11" Cobra clutch
* Yellow-Top battery
* 3:55 gears
... it's ALL about the twisties, baby :cool:
The Jazz.... bendin' the rules :)
1 - 3 of 3 Posts
Status
