1 - 20 of 24 Posts
· Registered
Is the electric 3.8 taurus fan better then the stock fan? And at what CFM does the stock fan flow at? My dad says that the stock fan will be better since it's mechanical it will do a better job at keeping the engine cooler he says. I believe that he's completely wrong and that the electric fan will outperform the mechanical one by alot.
· Registered
the electric fan will pull 2200 or 4000 cfm depending on which wire u hook it up to.. and u will gain hp your engine will stay plenty cool enough with that fan over the stock clutch fan i am going to use mine on my 347 stroker with a standard flow waterpump.. i do have an aluminum raidaitor but u will be fine with a stock motor.
· Registered
So your saying that the electric fan will keep the engine alot cooler then the clutch fan?
· Registered
Alright thanks I saw you posted before around $20-30 dollars at the junkjard?
· Registered
Well the big advantage of the electric is it is only on when you need it. Like when you are driving on the freeway, you don't need a fan, so it is off.
· Registered
will the stock alternator be able to handle it? Or should I upgrade to a 150 amp before hand? Or what do I do If I want to upgrade to the 200 amp alternator?
· Registered
Well, it will be a strain for sure. The stock alt puts out like 75 amps on a good day. A good fan will draw about 15 amps, leaving 60 amps for everything else. At idle, it might only leave 40 amps for everything else...
· Registered
imo you should upgrade the stock alternator to a 3g anyway but as far as amps 100 would probly be fine.....having the bigger ones wont hurt tho
· Registered
Discussion Starter · #11 ·
I saw a 150 amp one wire one, that's supposed to just bolt right on would that one be good?
· Registered
thats what i have and it seems fine.....it doesnt but out the volts i thot it would though
· Registered
Discussion Starter · #13 ·
Does it at least give you alot more over stock or no? And did you just connect it to one spot or did anything else to it?
· Registered
yeah it doesnt pull down that easy.....usually it sits at about 13.8 volts and i was expecting more like 14.4 but oh well....as far as hooking it up you just run that one wire to the positive on the battery and thats it.....the two plugs that are on the original alternator you just leave hanging.....i know it sounds weird but thats all you do to hook it up
· Registered
Discussion Starter · #15 ·
lol idk about getting that one then it just doesnt seem right, just connecting it to the battery.. what if something goes wrong..
· Registered
what do you mean if something goes wrong......its still charging everything and the gauge still works......those volt numbers i was giving were from my radar detector
· Registered
Discussion Starter · #17 ·
what were the volts at stock? And could I just cut the two wires that were connected to the alternator?
· Registered
i cant remember for sure what they were stock......maybe 13.6 but it didnt take much to pull it down....with the headlights and heater it was gettin down in the mid twelves or so......my is reman. though....my stock tacoma alt sits at 14.3 usually and its only 80 amp is why i expected the volts to read higher
· Registered
Discussion Starter · #19 ·
ohhh alright thanks, because now with my lights on, radio, at idle my voltage drops alot it gets really close to red
· Registered
yeah thats because its a 2g externally regulated alt and the upgrade is a 3g internally regulated......one of the best parts about it is the much better voltage at idle
1 - 20 of 24 Posts
