Good Day.
I have an 2007 GT with an SM aluminum driveshaft. When I got the car there were no vibration issues. I had 4.10’s installed I got vibrations at all speed. It gets worse at the 65-75mph range. I was putting up with it until I was able to gather all the rear suspension parts. Instead I picked up a 2010 GT and I am now selling the 07. I took the SM out of the 07’ and put it in the 10’ , no vibrations. I put the 10’ stock shaft in the 07’ and I have vibration only at low speeds like taking off from a dead stop. I have not checked my pinion angle yet but I suspect it is off based on the vibrations after the gear change.
Before I spend another couple hundred bucks will an adjustable UCA fix this problem?
Thanks.
Thanks.
